MaxWest TAB-7360DC Battery Replacement
    1. MaxWest TAB-7360DC Battery Replacement, Back Hard Case: step 1, image 1 of 3 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: step 1, image 2 of 3 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: step 1, image 3 of 3
      • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
      • Volume buttons will fall out during removal.
      • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
      Ask FixBot
    2. MaxWest TAB-7360DC Battery Replacement: step 2, image 1 of 2 MaxWest TAB-7360DC Battery Replacement: step 2, image 2 of 2
      • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
      • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
      Ask FixBot
    3. MaxWest TAB-7360DC Battery Replacement: step 3, image 1 of 1
      • Gently unclip the data cable retainers and remove the wires from the junctions.
      • Peel the tape off the wire near the bottom of the case.
      Ask FixBot
    4. MaxWest TAB-7360DC Battery Replacement: step 4, image 1 of 1
      • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
      • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
      Ask FixBot
    5. MaxWest TAB-7360DC Battery Replacement: step 5, image 1 of 1
      • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
      • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
      Ask FixBot
Gillian Bundles
230 Reputation
1 Guide authored
IUPUI, Team S4-G3, Baechle Spring 2018 Member of IUPUI, Team S4-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 35
All Time: 2,320
