Up to 20% off select tools
Mavic 2 Main Board Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
111
All Time:
2,625
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
  1. Turn drone upside down to expose underside plate.
  2. Begin to remove all 8 screws from the plate . Remember the 2 middle screws are bigger than the other 6 so set those aside separately.
  3. Pull plate off, exposing the main board.
  4. Detach 3 ribbons on the top of the board. Near the head of the drone. Use spreader.
  5. Remove screw holding circuit board in. 1 near the top, 2 near the bottom.
  6. Pop of all 4 antennas at the bottom of the circuit board. Use spreader.
  7. Pull away antennas and remove board carefully.
  8. Replace new circuit board.
  9. Attach 3 ribbons.
  10. Attach 4 antennas.
  11. Screw circuit board back in.
  12. Place the plate back on and screw back in all 8 screws.
    1. Mavic 2 Main Board  Replacement, Remove screws: step 1, image 1 of 1
      • Begin to remove screws from belly of drone.
      Ask FixBot
    2. Mavic 2 Main Board  Replacement, Continue to remove screws: step 2, image 1 of 3 Mavic 2 Main Board  Replacement, Continue to remove screws: step 2, image 2 of 3 Mavic 2 Main Board  Replacement, Continue to remove screws: step 2, image 3 of 3
      • remove the rest of the screws
      Ask FixBot
    3. Mavic 2 Main Board  Replacement: step 3, image 1 of 2 Mavic 2 Main Board  Replacement: step 3, image 2 of 2
      • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
      Ask FixBot
    4. Mavic 2 Main Board  Replacement: step 4, image 1 of 1
      • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
      Ask FixBot
    5. Mavic 2 Main Board  Replacement: step 5, image 1 of 1
      • Then remove the old board. Replace the new board you have and repeat the process in reverse.
      Ask FixBot
4 other people completed this guide.
Author
with
Robert Contraction
229 Reputation
1 Guide authored
1 Guide Comment
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 111
All Time: 2,625
