Mavic 2 Camera/Gimbal Unit Replacement
    1. Mavic 2 Camera/Gimbal Unit Replacement, Remove the bottom cover: step 1, image 1 of 1
      • Remove the two 2x5 mm screws from the plastic piece near the camera on the bottom side using the Allen key.
      Ask FixBot
    2. Mavic 2 Camera/Gimbal Unit Replacement: step 2, image 1 of 1
      • Remove the plastic part from the previous step.
      Ask FixBot
    3. Mavic 2 Camera/Gimbal Unit Replacement: step 3, image 1 of 1
      • Remove the ribbon cable connecting to the camera by pulling at the camera connection point.
      • Be careful not to damage the surrounding wires! Pull the cable out slowly.
      Ask FixBot
    4. Mavic 2 Camera/Gimbal Unit Replacement: step 4, image 1 of 1
      • Unscrew the 1.5 x 4.5 mm gimbal mount screw using an Allen key.
      Ask FixBot
    5. Mavic 2 Camera/Gimbal Unit Replacement, Remove nose plate screws: step 5, image 1 of 1
      • Use an Allen key to remove the screws holding the nose plate in the front left and right corners in front of the camera.
      Ask FixBot
    6. Mavic 2 Camera/Gimbal Unit Replacement, Remove camera and gimbal: step 6, image 1 of 1
      • Pull the camera and gimbal from the drone.
      • Be cautious of the surrounding wires.
      Ask FixBot
    7. Mavic 2 Camera/Gimbal Unit Replacement, Camera mount: step 7, image 1 of 1
      • Remove the four rubber parts from the camera mount.
      Ask FixBot
    8. Mavic 2 Camera/Gimbal Unit Replacement, Seperate camera from frame: step 8, image 1 of 1
      • Remove the camera from the frame by pulling it apart.
      Ask FixBot
      • Now insert the new camera and reverse these steps to replace the camera back into your DJI Mavic 2 Pro drone.
      Ask FixBot
ColynOB
187 Reputation
1 Guide authored
IUPUI, Team 2-3, Harley Fall 2023 Member of IUPUI, Team 2-3, Harley Fall 2023
IUPUI-HARLEY-F23S2G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 106
All Time: 1,911
