Up to 20% off select tools
Mavic 2 Arm Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
144
All Time:
2,697
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 - 45 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
This guide describes how to replace the arms that position the propellers for the Mavic 2 drone.
    1. Mavic 2 Arm Replacement, Front Arm (Left or Right): step 1, image 1 of 1
      • Remove the two M2x5 screws from the plastic cover by the camera using and H1.5 Allen bit.
      Ask FixBot
    2. Mavic 2 Arm Replacement: step 2, image 1 of 1
      • Gently remove the cover by the front camera by wiggling out the clips holding it in on both sides.
      Ask FixBot
    3. Mavic 2 Arm Replacement: step 3, image 1 of 3 Mavic 2 Arm Replacement: step 3, image 2 of 3 Mavic 2 Arm Replacement: step 3, image 3 of 3
      • Remove the six M2x5 screws from the bottom plastic cover using a H1.5 Allen bit.
      • Remove the plastic cover once all screws are extracted.
      Ask FixBot
    4. Mavic 2 Arm Replacement: step 4, image 1 of 2 Mavic 2 Arm Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers or a plastic pick, remove either the white or black wire plugging into the board.
      • Be gentle removing the wire from the plug, you can damage the plug on the board.
      • The wire being pulled depends on which arm is being replaced. The wire that is closest to the arm being replaced is the one to unplug.
      Ask FixBot
    5. Mavic 2 Arm Replacement: step 5, image 1 of 3 Mavic 2 Arm Replacement: step 5, image 2 of 3 Mavic 2 Arm Replacement: step 5, image 3 of 3
      • Unscrew the two M2x5 screws holding on the front nose.
      • Using a plastic pry tool, gently pry along the seem around the front nose to remove it.
      Ask FixBot
    6. Mavic 2 Arm Replacement: step 6, image 1 of 2 Mavic 2 Arm Replacement: step 6, image 2 of 2
      • Remove all ten M2x5 mm screws holding the top plastic cover of the drone. Two at the back, four in the battery bay, and two at each front arm joint.
      • At each arm joint, only one screw is visible. The second screw is under the plastic piece being held on by the first screw.
      Ask FixBot
    7. Mavic 2 Arm Replacement: step 7, image 1 of 3 Mavic 2 Arm Replacement: step 7, image 2 of 3 Mavic 2 Arm Replacement: step 7, image 3 of 3
      • Using a plastic pry tool, pry along the seem around the top cover to separate it from the chassis. Be patient as it does take a bit of time and effort to get it off.
      Ask FixBot
    8. Mavic 2 Arm Replacement: step 8, image 1 of 2 Mavic 2 Arm Replacement: step 8, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the screw that secures the arm spring.
      • Then remove the spring, use either tweezers or a flat-head screwdriver to lift it up out of the arm.
      Ask FixBot
    9. Mavic 2 Arm Replacement: step 9, image 1 of 2 Mavic 2 Arm Replacement: step 9, image 2 of 2
      • On the topside of the drone,desolder the wires from the main board that correspond to the arm trying to be replaced, there should be six in total.
      • Remove the arm once all wires are desoldered.
      • Make note of where each wire goes on the board as the colors may not be the same across all models.
      Ask FixBot
Author
with
Nick Imel
190 Reputation
1 Guide authored
IUPUI, Team 2-3, Harley Fall 2023 Member of IUPUI, Team 2-3, Harley Fall 2023
IUPUI-HARLEY-F23S2G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 144
All Time: 2,697
