Master and Dynamic MW50 Right/Left Speaker Replacement
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: step 1, image 1 of 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: step 1, image 2 of 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: step 1, image 3 of 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
    Ask FixBot
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: step 2, image 1 of 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
    Ask FixBot
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: step 3, image 1 of 1
    • Use the Jimmy to lift up the black cover to get inside the device.
    Ask FixBot
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: step 4, image 1 of 1
    • Desolder the two wires connected to the speaker.
    Ask FixBot
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: step 5, image 1 of 1
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
    Ask FixBot
Katie Dunnigan
85 Reputation
1 Guide authored
Cal Poly, Team S1-G4, White Winter 2019 Member of Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Members
12 Guides authored
1 Guide Comment
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 27
All Time: 1,068
