Up to 20% off select tools
Master and Dynamic MW50 Disassembly
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
61
All Time:
1,122
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Master and Dynamic MW50 Disassembly, Master and Dynamic MW50 Disassembly: step 1, image 1 of 3 Master and Dynamic MW50 Disassembly, Master and Dynamic MW50 Disassembly: step 1, image 2 of 3 Master and Dynamic MW50 Disassembly, Master and Dynamic MW50 Disassembly: step 1, image 3 of 3
      • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
      Ask FixBot
    2. Master and Dynamic MW50 Disassembly: step 2, image 1 of 1
      • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
      Ask FixBot
    3. Master and Dynamic MW50 Disassembly: step 3, image 1 of 1
      • Use the Jimmy to lift up the black cover to get inside the device.
      Ask FixBot
Author
with
Ryan Chan
297 Reputation
2 Guides authored
Cal Poly, Team S1-G4, White Winter 2019 Member of Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Members
72 Guides authored
1 Guide Comment
My right side doesn’t work on Bluetooth mode but works fine with ord any help would be greatly appreciated
James Dunleavy - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 61
All Time: 1,122
