Master and Dynamic MW50 Charging Port Replacement
    1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: step 1, image 1 of 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: step 1, image 2 of 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: step 1, image 3 of 3
      • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
      Ask FixBot
    2. Master and Dynamic MW50 Charging Port Replacement: step 2, image 1 of 1
      • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
      Ask FixBot
    3. Master and Dynamic MW50 Charging Port Replacement: step 3, image 1 of 1
      • Use the Jimmy to lift up the black cover to get inside the device.
      Ask FixBot
    1. Master and Dynamic MW50 Charging Port Replacement, Charging Port: step 4, image 1 of 2 Master and Dynamic MW50 Charging Port Replacement, Charging Port: step 4, image 2 of 2
      • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
      • Gently pull the silver cover off of the ear piece.
      Ask FixBot
    2. Master and Dynamic MW50 Charging Port Replacement: step 5, image 1 of 1
      • Remove the two 2mm screws shown with a JIS #00 screwdriver.
      Ask FixBot
    3. Master and Dynamic MW50 Charging Port Replacement: step 6, image 1 of 1
      • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
      Ask FixBot
Tyler Guffey
208 Reputation
2 Guides authored
Cal Poly, Team S1-G4, White Winter 2019 Member of Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 676
