Marvel iHome MR-M66 Back Cover Replacement
    1. Marvel iHome MR-M66 Back Cover Replacement, Back Cover: step 1, image 1 of 2 Marvel iHome MR-M66 Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Remove two of the three screws shown on the bottom of the device.
      • Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
      Ask FixBot
    2. Marvel iHome MR-M66 Back Cover Replacement: step 2, image 1 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 2, image 2 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 2, image 3 of 3
      • Remove the bottom cover by either pulling on the screw or using a plastic opening tool to pry the cover off.
      • After removing the bottom cover, remove the two screws.
      Ask FixBot
    3. Marvel iHome MR-M66 Back Cover Replacement: step 3, image 1 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 3, image 2 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 3, image 3 of 3
      • Use a spudger to release the small retaining clip that holds the feet to the bottom of the device.
      • Be careful here, as too much force can break the clip.
      • Remove the two screws from the back of the device.
      Ask FixBot
    4. Marvel iHome MR-M66 Back Cover Replacement: step 4, image 1 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 4, image 2 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 4, image 3 of 3
      • Using a plastic opening tool and your hand, separate the front and back covers from each other.
      • Starting from the bottom, use the plastic opening tool to create the initial separation and continue along the seam to the top of the device.
      • This step requires the most time and patience, so be careful.
      • The power switch will most likely come loose during this step and you will hear something rattling inside the device.
      Ask FixBot
    5. Marvel iHome MR-M66 Back Cover Replacement: step 5, image 1 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 5, image 2 of 3 Marvel iHome MR-M66 Back Cover Replacement: step 5, image 3 of 3
      • Remove the two arms from either side of the device once a significant separation has been created.
      • They are not fixed to the body itself so you should be able to wiggle them free.
      • Continue pulling the back cover off the device.
      • Remove the red cover for the on/off switch from the device.
      Ask FixBot
Aaram Williams
201 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 334
