MartinLogan Motion 4i Crossover Replacement
    1. MartinLogan Motion 4i Crossover Replacement, Back Cover: step 1, image 1 of 2 MartinLogan Motion 4i Crossover Replacement, Back Cover: step 1, image 2 of 2
      • Remove the speaker grill from the face of the speaker by using both hands to grip both ends of the speaker grill and pulling up to release the magnetic ends.
      Ask FixBot
    2. MartinLogan Motion 4i Crossover Replacement: step 2, image 1 of 3 MartinLogan Motion 4i Crossover Replacement: step 2, image 2 of 3 MartinLogan Motion 4i Crossover Replacement: step 2, image 3 of 3
      • Remove the six caps from the outer edge of the face of the speaker with an iFixit opening tool.
      • Make sure to remove the rubber caps slowly and carefully so that the ends won't break off and create a blockage above the screws.
      Ask FixBot
    3. MartinLogan Motion 4i Crossover Replacement: step 3, image 1 of 1
      • Remove the six 4 mm Phillips #2 screws that are located inside each of the holes where the rubber caps used to be.
      • The screws vary in depth, therefore you will need a Phillips #2 screwdriver that is around 6 inches in length from the tip to the start of the handle.
      Ask FixBot
    4. MartinLogan Motion 4i Crossover Replacement: step 4, image 1 of 1
      • Place the device face-down, then lift off the back case with both hands.
      • The speaker sometimes takes a little effort to remove the speaker back, so we recommend that you give it a couple shakes by placing each hand on the speaker face and the back when shaking.
      • If you decide to use the shaking method, make sure you're near an immediate surface near you just in case it drops.
      Ask FixBot
    5. MartinLogan Motion 4i Crossover Replacement: step 5, image 1 of 1
      • Lightly grip the material that insulates and covers the speaker components and remove it by pulling up.
      Ask FixBot
    6. MartinLogan Motion 4i Crossover Replacement: step 6, image 1 of 2 MartinLogan Motion 4i Crossover Replacement: step 6, image 2 of 2
      • Remove both wires that are connecting the back of the speaker to the components of the speaker to fully access the speaker components.
      Ask FixBot
    1. MartinLogan Motion 4i Crossover Replacement, Crossover: step 7, image 1 of 2 MartinLogan Motion 4i Crossover Replacement, Crossover: step 7, image 2 of 2
      • Remove the four 3 mm Phillips #2 screws found at the top of the crossover.
      Ask FixBot
    2. MartinLogan Motion 4i Crossover Replacement: step 8, image 1 of 1
      • Using the soldering iron, remove the solder from the connections that are holding the wires in place before removing the connections entirely.
      • When removing and replacing the crossover, use extra care when using the soldering iron. The iron is incredibly hot and can burn the user if it is not handled with care.
      Ask FixBot
Sabastien Paige
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 333
