Martian Victory Watch band Replacement
  1. Martian Victory Watch band Replacement, Watch band: step 1, image 1 of 1
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
    Ask FixBot
  2. Martian Victory Watch band Replacement: step 2, image 1 of 1
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
    Ask FixBot
  3. Martian Victory Watch band Replacement: step 3, image 1 of 1
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
    Ask FixBot
Dominic Coffey
243 Reputation
2 Guides authored
IUPUI, Team 3-3, Baechle Fall 2016 Member of IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 598
