Martian Victory Motherboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
77
All Time:
600
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 8 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
How to access and remove the motherboard of the Martian Smartwatch
Tools
    1. Martian Victory Motherboard  Replacement, Back Plate: step 1, image 1 of 2 Martian Victory Motherboard  Replacement, Back Plate: step 1, image 2 of 2
      • Unscrew the four 3.4 mm flat head screws
      Ask FixBot
    2. Martian Victory Motherboard  Replacement: step 2, image 1 of 1
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      Ask FixBot
    1. Martian Victory Motherboard  Replacement, Lithium Battery: step 3, image 1 of 1
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      Ask FixBot
    2. Martian Victory Motherboard  Replacement: step 4, image 1 of 1
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      Ask FixBot
    1. Martian Victory Motherboard  Replacement, Motherboard: step 5, image 1 of 1
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
      Ask FixBot
    2. Martian Victory Motherboard  Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
      Ask FixBot
    3. Martian Victory Motherboard  Replacement: step 7, image 1 of 1
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
      Ask FixBot
    4. Martian Victory Motherboard  Replacement: step 8, image 1 of 3 Martian Victory Motherboard  Replacement: step 8, image 2 of 3 Martian Victory Motherboard  Replacement: step 8, image 3 of 3
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
      Ask FixBot
    5. Martian Victory Motherboard  Replacement: step 9, image 1 of 2 Martian Victory Motherboard  Replacement: step 9, image 2 of 2
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
      Ask FixBot
Dominic Coffey
243 Reputation
2 Guides authored
IUPUI, Team 3-3, Baechle Fall 2016 Member of IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 77
All Time: 600
