Up to 20% off select tools
Martian Victory LED Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
107
All Time:
718
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
    1. Martian Victory LED Screen Replacement, Back Plate: step 1, image 1 of 2 Martian Victory LED Screen Replacement, Back Plate: step 1, image 2 of 2
      • Unscrew the four 3.4 mm flat head screws
      Ask FixBot
    2. Martian Victory LED Screen Replacement: step 2, image 1 of 1
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      Ask FixBot
    1. Martian Victory LED Screen Replacement, Lithium Battery: step 3, image 1 of 1
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      Ask FixBot
    2. Martian Victory LED Screen Replacement: step 4, image 1 of 1
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      Ask FixBot
    1. Martian Victory LED Screen Replacement, LED Screen: step 5, image 1 of 1
      • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
      Ask FixBot
    2. Martian Victory LED Screen Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • With a pair of tweezers, carefully remove the ribbon strip connection.
      Ask FixBot
    3. Martian Victory LED Screen Replacement: step 7, image 1 of 1
      • Remove the screw driver holding the LED screen and Speaker in place.
      Ask FixBot
    4. Martian Victory LED Screen Replacement: step 8, image 1 of 1
      • Insert a small flat screw driver under the speaker in order to remove it.
      Ask FixBot
    5. Martian Victory LED Screen Replacement: step 9, image 1 of 2 Martian Victory LED Screen Replacement: step 9, image 2 of 2
      • Using tweezers, remove the speaker and move off to the side.
      Ask FixBot
    6. Martian Victory LED Screen Replacement: step 10, image 1 of 2 Martian Victory LED Screen Replacement: step 10, image 2 of 2
      • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
      Ask FixBot
    7. Martian Victory LED Screen Replacement: step 11, image 1 of 1
      • Remove final connection to accelerometer. The LED screen is now separated from the device.
      Ask FixBot
Author
with
Robert Sanchez
201 Reputation
2 Guides authored
IUPUI, Team 3-3, Baechle Fall 2016 Member of IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 107
All Time: 718
