Introduction
Go to step 1 ↓If you are still experiencing power issues with your Marshall Uxbridge speaker (model 1005605) after replacing the power cord Marshall Uxbridge Power Port Replacement, use this guide to replace the power relay.
A power relay transmits power inside the device. Sometimes a power surge can cause them to malfunction.
Before using this guide, inspect the device for debris. To clean dust or debris try following these steps
Before beginning make sure to power off the speaker completely and unplug from the power source.
Tools
Orient your speaker so that the back is facing you.
Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
Orient the bottom of the speaker to face away from you.
Use a Phillips #1 screwdriver to remove the two 12 mm screws holding the power relay in place.
