Marshall Uxbridge Power Port Replacement
  1. Marshall Uxbridge Power Port Replacement, Back Panel: step 1, image 1 of 3 Marshall Uxbridge Power Port Replacement, Back Panel: step 1, image 2 of 3 Marshall Uxbridge Power Port Replacement, Back Panel: step 1, image 3 of 3
    • Orient your speaker so that the back is facing you.
    • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
    • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
    Ask FixBot
  2. Marshall Uxbridge Power Port Replacement: step 2, image 1 of 2 Marshall Uxbridge Power Port Replacement: step 2, image 2 of 2
    • Detach the white connector from inside the bottom of the back panel.
    • Detach the small red and white connectors from the motherboard on the left side of the back panel.
    Ask FixBot
  3. Marshall Uxbridge Power Port Replacement: step 3, image 1 of 1
    • Pull the blue ribbon cables from the motherboard.
    • Remove the back panel from the speaker base.
    Ask FixBot
  4. Marshall Uxbridge Power Port Replacement, Power Port: step 4, image 1 of 2 Marshall Uxbridge Power Port Replacement, Power Port: step 4, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two 12 mm screws holding the power port to the back plate.
    • Remove the power port from the back plate.
    Ask FixBot
  5. Marshall Uxbridge Power Port Replacement: step 5, image 1 of 1
    • Follow the power port wire and locate the white connector.
    Ask FixBot
  6. Marshall Uxbridge Power Port Replacement: step 6, image 1 of 2 Marshall Uxbridge Power Port Replacement: step 6, image 2 of 2
    • Unplug the power port cord from the board at the white connector by pushing down on the tab, holding onto the connector, and pulling the connector out.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 247
