Marshall Uxbridge Motherboard Replacement
  1. Marshall Uxbridge Motherboard Replacement, Back Panel: step 1, image 1 of 3 Marshall Uxbridge Motherboard Replacement, Back Panel: step 1, image 2 of 3 Marshall Uxbridge Motherboard Replacement, Back Panel: step 1, image 3 of 3
    • Orient your speaker so that the back is facing you.
    • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
    • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
    Ask FixBot
  2. Marshall Uxbridge Motherboard Replacement: step 2, image 1 of 2 Marshall Uxbridge Motherboard Replacement: step 2, image 2 of 2
    • Detach the white connector from inside the bottom of the back panel.
    • Detach the small red and white connectors from the motherboard on the left side of the back panel.
    Ask FixBot
  3. Marshall Uxbridge Motherboard Replacement: step 3, image 1 of 1
    • Pull the blue ribbon cables from the motherboard.
    • Remove the back panel from the speaker base.
    Ask FixBot
  4. Marshall Uxbridge Motherboard Replacement, Motherboard: step 4, image 1 of 2 Marshall Uxbridge Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the six 12 mm screws from the motherboard.
    Ask FixBot
  5. Marshall Uxbridge Motherboard Replacement: step 5, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the two 6 mm black screws holding the black board that says "LinkPlay" in place.
    Ask FixBot
  6. Marshall Uxbridge Motherboard Replacement: step 6, image 1 of 2 Marshall Uxbridge Motherboard Replacement: step 6, image 2 of 2
    • Use a TR 6 Torx screwdriver to remove the two silver 6 mm screws from the LinkPlay board.
    Ask FixBot
  7. Marshall Uxbridge Motherboard Replacement: step 7, image 1 of 2 Marshall Uxbridge Motherboard Replacement: step 7, image 2 of 2
    • Lift the motherboard.
    • Slide the LinkPlay board down to remove the motherboard from the back panel.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 37
All Time: 370
