Up to 20% off select tools
Marshall Uxbridge Back Panel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
62
All Time:
424
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Marshall Uxbridge Back Panel Replacement, Back Panel: step 1, image 1 of 3 Marshall Uxbridge Back Panel Replacement, Back Panel: step 1, image 2 of 3 Marshall Uxbridge Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Orient your speaker so that the back is facing you.
      • Use a Phillips #2 screwdriver to remove the six 19mm screws from the back plate.
      • Use an iFixit opening pick to remove and lift the back plate to expose the connected wires.
      Ask FixBot
    2. Marshall Uxbridge Back Panel Replacement: step 2, image 1 of 2 Marshall Uxbridge Back Panel Replacement: step 2, image 2 of 2
      • Detach the white connector from inside the bottom of the back panel.
      • Detach the small red and white connectors from the motherboard on the left side of the back panel.
      Ask FixBot
    3. Marshall Uxbridge Back Panel Replacement: step 3, image 1 of 1
      • Pull the blue ribbon cables from the motherboard.
      • Remove the back panel from the speaker base.
      Ask FixBot
Kristen Gismondi
110,406 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 62
All Time: 424
