Up to 20% off select tools
Marshall Stanmore II Tweeter Assembly Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
126
All Time:
1,189
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is to be used for the replacement of one or both tweeter assemblies in the Marshall Stanmore II Bluetooth Speaker.
The tweeters produce high-frequency sounds in a speaker. These high-frequency sounds allow listeners to hear the treble in music. If a speaker has a malfunctioning tweeter, anything played would sound muddy and incomprehensible.
Before using this guide, make any adjustments for the treble and bass using the dials on top of the speaker or through the Marshall Bluetooth app. After adjustment, verify if the sound quality has improved. If there is no improvement, follow the troubleshooting steps on the Marshall Stanmore II Bluetooth Speaker Troubleshooting page before attempting to disassemble.
    1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: step 1, image 1 of 2 Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: step 1, image 2 of 2
      • Turn off the device and unplug the cable from the wall and the speaker.
      • Lay the speaker with the back panel facing up on a flat, stable work surface.
      Ask FixBot
    2. Marshall Stanmore II Tweeter Assembly Replacement: step 2, image 1 of 2 Marshall Stanmore II Tweeter Assembly Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
      Ask FixBot
    3. Marshall Stanmore II Tweeter Assembly Replacement: step 3, image 1 of 2 Marshall Stanmore II Tweeter Assembly Replacement: step 3, image 2 of 2
      • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
      • Do not attempt to fully remove the panel, as this will damage the connections inside.
      Ask FixBot
    1. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: step 4, image 1 of 2 Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: step 4, image 2 of 2
      • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
      Ask FixBot
    2. Marshall Stanmore II Tweeter Assembly Replacement: step 5, image 1 of 3 Marshall Stanmore II Tweeter Assembly Replacement: step 5, image 2 of 3 Marshall Stanmore II Tweeter Assembly Replacement: step 5, image 3 of 3
      • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
      • Repeat for the second connector.
      Ask FixBot
    3. Marshall Stanmore II Tweeter Assembly Replacement: step 6, image 1 of 2 Marshall Stanmore II Tweeter Assembly Replacement: step 6, image 2 of 2
      • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
      • Lift the tweeter assembly from its housing.
      Ask FixBot
    4. Marshall Stanmore II Tweeter Assembly Replacement: step 7, image 1 of 1
      • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
      • Repeat steps 4-6 to remove the second tweeter if necessary.
      Ask FixBot
Author
with
Jacob Rose Parks
527 Reputation
4 Guides authored
1 Guide Comment
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 126
All Time: 1,189
