Marshall Stanmore II Subwoofer Assembly Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
8
Past 7 Days:
31
Past 30 Days:
125
All Time:
1,657
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is intended to replace the subwoofer in the Marshall Stanmore II Bluetooth Speaker.
The subwoofer produces the low-frequency sounds in a speaker. Low-frequency sounds--or bass--are what allow the listener to feel the richness and depth of music. Without bass, anything played through the speaker would sound tinny and mechanical.
Before using this guide, check the adjustments for the bass and treble using the dials on top of the speaker or through the Marshall Bluetooth app. Adjusting these configurations usually fixes any sound quality issues one may come across when this problem arises. If adjusting the bass and treble doesn't solve the issue, follow the troubleshooting steps on the Marshall Stanmore II Bluetooth Speaker Troubleshooting page for more possible solutions before disassembling the device.
Before removal, take note of the magnet that is on the subwoofer. Try to keep magnet-sensitive items concealed, or away, during removal.
Tools
    1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: step 1, image 1 of 2 Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: step 1, image 2 of 2
      • Turn off the device and unplug the cable from the wall and the speaker.
      • Lay the speaker with the back panel facing up on a flat, stable work surface.
      Ask FixBot
    2. Marshall Stanmore II Subwoofer Assembly Replacement: step 2, image 1 of 2 Marshall Stanmore II Subwoofer Assembly Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
      Ask FixBot
    3. Marshall Stanmore II Subwoofer Assembly Replacement: step 3, image 1 of 2 Marshall Stanmore II Subwoofer Assembly Replacement: step 3, image 2 of 2
      • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
      • Do not attempt to fully remove the panel, as this will damage the connections inside.
      Ask FixBot
    1. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: step 4, image 1 of 3 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: step 4, image 2 of 3 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: step 4, image 3 of 3
      • Pull back the clear sheaths on the end of each wire to expose the terminals.
      • Using a pair of tweezers, or your fingernail, depress the small latch and gently pull the wire off of the metal tabs.
      • Failure to press the latch while pulling could damage the subwoofer and/or wires.
      Ask FixBot
    2. Marshall Stanmore II Subwoofer Assembly Replacement: step 5, image 1 of 1
      • Remove the six 20.5 mm T20 Torx screws that secure the subwoofer to the housing.
      • The subwoofer assembly contains a very strong magnet, so the screwdriver and screws may occasionally stick to the side of the assembly.
      Ask FixBot
    3. Marshall Stanmore II Subwoofer Assembly Replacement: step 6, image 1 of 1
      • Carefully lift the subwoofer assembly away from the housing.
      Ask FixBot
    4. Marshall Stanmore II Subwoofer Assembly Replacement: step 7, image 1 of 1
      • Optional: Inspect the felt gasket on the speaker frame for any tears or foreign material.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 31
Past 30 Days: 125
All Time: 1,657
