Marshall Stanmore II Rear Panel Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
119
All Time:
1,987
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This prerequisite guide is intended to facilitate the replacement of any internal components of the Marshall Stanmore II Bluetooth Speaker. It may also be used to check inside and clean out any water or debris.
Before using this guide, ensure that all steps have been taken on the Stanmore II Troubleshooting page in case the issue can be solved without disassembling the device.
Before removing the panel, make sure that power is removed from the speaker. This includes turning off the speaker and unplugging the power cord from the back of the device and the wall outlet.
Tools
    1. Marshall Stanmore II Rear Panel Replacement, Rear Panel: step 1, image 1 of 2 Marshall Stanmore II Rear Panel Replacement, Rear Panel: step 1, image 2 of 2
      • Turn off the device and unplug the cable from the wall and the speaker.
      • Lay the speaker with the back panel facing up on a flat, stable work surface.
      Ask FixBot
    2. Marshall Stanmore II Rear Panel Replacement: step 2, image 1 of 2 Marshall Stanmore II Rear Panel Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
      Ask FixBot
    3. Marshall Stanmore II Rear Panel Replacement: step 3, image 1 of 2 Marshall Stanmore II Rear Panel Replacement: step 3, image 2 of 2
      • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
      • Do not attempt to fully remove the panel, as this will damage the connections inside.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 119
All Time: 1,987
