Marshall Stanmore II Power Jack Replacement
  1. Marshall Stanmore II Power Jack Replacement, Rear Panel: step 1, image 1 of 2 Marshall Stanmore II Power Jack Replacement, Rear Panel: step 1, image 2 of 2
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    Ask FixBot
  2. Marshall Stanmore II Power Jack Replacement: step 2, image 1 of 2 Marshall Stanmore II Power Jack Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    Ask FixBot
  3. Marshall Stanmore II Power Jack Replacement: step 3, image 1 of 2 Marshall Stanmore II Power Jack Replacement: step 3, image 2 of 2
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    Ask FixBot
  4. Marshall Stanmore II Power Jack Replacement, Power Jack: step 4, image 1 of 2 Marshall Stanmore II Power Jack Replacement, Power Jack: step 4, image 2 of 2
    • Set the panel back in place.
    • Use a #1 Phillips screwdriver to remove the two 11.7 mm screws that secure the power jack.
    • When removed for the first time, the jack will remain in place until it is pulled out.
    Ask FixBot
  5. Marshall Stanmore II Power Jack Replacement: step 5, image 1 of 2 Marshall Stanmore II Power Jack Replacement: step 5, image 2 of 2
    • Find the power jack cable inside of the removable panel. It is located in the upper, right corner of the panel interior.
    Ask FixBot
  6. Marshall Stanmore II Power Jack Replacement: step 6, image 1 of 3 Marshall Stanmore II Power Jack Replacement: step 6, image 2 of 3 Marshall Stanmore II Power Jack Replacement: step 6, image 3 of 3
    • Depress the white plastic clip while pulling the connector up.
    • Remove the power jack.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 39
All Time: 968
