Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓Here is how to replace the hinge on Marshall Major IV headphones.
Use a pointy object like a screwdriver, or your finger if you are handy, to remove the pin.
Ensure to align the headphone and its stem and insert the first part of the hinge inside
Using the iFixit opening tool, or any object made to break if you apply pressure that is too high, insert the hinge cover. It is the smaller piece that cover the stem. Do not hesitate to apply force, because everything is very tight.
Do this the same way the screw was removed; by applying pressure on the screw.
To adjust the stem, you need to apply a lot of force because everything is tight. The friction could make it easier to adjust over time, or it may be easier for you if you use another hinge
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
1 Guide Comment
bonjour, ou avez vous acheté la charnière de remplacement svp ?
