Marshall Kilburn Power Switch Replacement
    1. Marshall Kilburn Power Switch Replacement, Battery: step 1, image 1 of 2 Marshall Kilburn Power Switch Replacement, Battery: step 1, image 2 of 2
      • Place the unit face down as shown in the picture, exposing the battery cover.
      • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
      Ask FixBot
    2. Marshall Kilburn Power Switch Replacement: step 2, image 1 of 1
      • Remove the battery cover using a fingernail or nylon spudger.
      Ask FixBot
    3. Marshall Kilburn Power Switch Replacement: step 3, image 1 of 1
      • Remove the battery and unplug the power lead.
      Ask FixBot
    1. Marshall Kilburn Power Switch Replacement, Power Switch: step 4, image 1 of 3 Marshall Kilburn Power Switch Replacement, Power Switch: step 4, image 2 of 3 Marshall Kilburn Power Switch Replacement, Power Switch: step 4, image 3 of 3
      • Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
      • Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
      Ask FixBot
    2. Marshall Kilburn Power Switch Replacement: step 5, image 1 of 2 Marshall Kilburn Power Switch Replacement: step 5, image 2 of 2
      • Remove the back cover by using the vent hole as a grip.
      • Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
      • Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
      Ask FixBot
    3. Marshall Kilburn Power Switch Replacement: step 6, image 1 of 3 Marshall Kilburn Power Switch Replacement: step 6, image 2 of 3 Marshall Kilburn Power Switch Replacement: step 6, image 3 of 3
      • Pull the back cover attached to the motherboard to the side as shown in first image.
      • Remove the white insulator from the stereo speaker and place it to the side.
      Ask FixBot
    4. Marshall Kilburn Power Switch Replacement: step 7, image 1 of 2 Marshall Kilburn Power Switch Replacement: step 7, image 2 of 2
      • Place the speaker up right, and unscrew the golden bolt around the power switch with your hands, or a wrench.
      • Gently pull out the power switch as shown in the image.
      Ask FixBot
    5. Marshall Kilburn Power Switch Replacement: step 8, image 1 of 3 Marshall Kilburn Power Switch Replacement: step 8, image 2 of 3 Marshall Kilburn Power Switch Replacement: step 8, image 3 of 3
      • Use a slim spudger to wedge out the four red wires attached to the power switch.
      Ask FixBot
2 Guide Comments
And where to purchase a new switch???
Anders Skipper - Reply Share
Does the old switch have any writing on it?
Andrew S - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 102
All Time: 6,575
