Marshall Kilburn II Charging Port Replacement
    1. Marshall Kilburn II Charging Port Replacement, Battery: step 1, image 1 of 2 Marshall Kilburn II Charging Port Replacement, Battery: step 1, image 2 of 2
      • Flip the front of the Marshall Kilburn II on a flat surface so the back is facing you.
      • Use a Phillips #1 screwdriver to remove all ten 4 mm screws.
      Ask FixBot
    2. Marshall Kilburn II Charging Port Replacement: step 2, image 1 of 2 Marshall Kilburn II Charging Port Replacement: step 2, image 2 of 2
      • Lift the charging port cover.
      • Use a Phillips #1 screwdriver to remove the two 4 mm screws.
      Ask FixBot
    3. Marshall Kilburn II Charging Port Replacement: step 3, image 1 of 3 Marshall Kilburn II Charging Port Replacement: step 3, image 2 of 3 Marshall Kilburn II Charging Port Replacement: step 3, image 3 of 3
      • Slightly lift up the back cover of the speaker just enough to be able to see the inside compartment of the speaker.
      • Take care not to strain the attached cables.
      • You can use an opening tool to help pry up the back cover from the sides if the back cover doesn't lift up easily.
      • Lift the back cover just enough to be able to see the inside compartment of the speaker.
      Ask FixBot
    4. Marshall Kilburn II Charging Port Replacement: step 4, image 1 of 3 Marshall Kilburn II Charging Port Replacement: step 4, image 2 of 3 Marshall Kilburn II Charging Port Replacement: step 4, image 3 of 3
      • Locate the battery, which is attached on the inside bottom left corner. Refer to image 1.
      • Identify the black cable that connects from the battery to the back cover of the speaker.
      Ask FixBot
    5. Marshall Kilburn II Charging Port Replacement: step 5, image 1 of 2 Marshall Kilburn II Charging Port Replacement: step 5, image 2 of 2
      • Grip the white battery connector and pull it directly out of its socket.
      • Remove the battery by pulling the battery up out of its housing.
      • You will need to cut the white zip tie which holds the battery cable and the other cables together.
      Ask FixBot
    1. Marshall Kilburn II Charging Port Replacement, Charging Port: step 6, image 1 of 3 Marshall Kilburn II Charging Port Replacement, Charging Port: step 6, image 2 of 3 Marshall Kilburn II Charging Port Replacement, Charging Port: step 6, image 3 of 3
      • Disconnect the charging port by pressing the white tab and pulling up on the end of the cable connected to the back cover of the speaker.
      • Replace the charging port.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 57
All Time: 697
