Tools
Introduction
Go to step 1 ↓The main button on top of the Marshall Emberton speaker is used to navigate between tracks and also the volume. This guide provides detailed instructions on how to replace the main button on the Emberton Bluetooth speaker.
With constant pressure on the button, it may eventually wear out and stop working. Replacing the button is very simple and only requires a TR-9 screwdriver.
5 Guide Comments
The worst instruction I've ever seen in my life. If you do this, you will break your device.
@cooleo fortunately i figured it out but yeah you ned to disassemble multiple parts. disassemble from the front panel (marshal logo panel is pressure fit, undo the phillips, and take the board out behind it, and then take out the top out + switch.
