Marco TA1 Gas Bottle Replacement
    1. Marco TA1 Gas Bottle Replacement, Let's get ready: step 1, image 1 of 1
      • You need your TA1 handheld horn and a spare gas bottle to proceed.
      Ask FixBot
    2. Marco TA1 Gas Bottle Replacement, Remove the trumpet from the gas bottle: step 2, image 1 of 3 Marco TA1 Gas Bottle Replacement, Remove the trumpet from the gas bottle: step 2, image 2 of 3 Marco TA1 Gas Bottle Replacement, Remove the trumpet from the gas bottle: step 2, image 3 of 3
      • Press down the flap.
      • Be careful: if you press too much it may break.
      Ask FixBot
    3. Marco TA1 Gas Bottle Replacement, Push the half-circle lock: step 3, image 1 of 3 Marco TA1 Gas Bottle Replacement, Push the half-circle lock: step 3, image 2 of 3 Marco TA1 Gas Bottle Replacement, Push the half-circle lock: step 3, image 3 of 3
      • While pressing the flap, move the half-circle lock to free the trumpet from the tank.
      Ask FixBot
    4. Marco TA1 Gas Bottle Replacement, Remove the trumpet from the bottle: step 4, image 1 of 2 Marco TA1 Gas Bottle Replacement, Remove the trumpet from the bottle: step 4, image 2 of 2
      • You don't need the empty tank anymore. Dispose it like required from your local laws.
      Ask FixBot
    5. Marco TA1 Gas Bottle Replacement, Take the new gas bottle: step 5, image 1 of 1
      • Take the new bottle and remove the cap.
      Ask FixBot
    6. Marco TA1 Gas Bottle Replacement, Open the lock: step 6, image 1 of 2 Marco TA1 Gas Bottle Replacement, Open the lock: step 6, image 2 of 2
      • Open the lock on the trumpet.
      Ask FixBot
    7. Marco TA1 Gas Bottle Replacement, Put the trumpet on the bottle: step 7, image 1 of 2 Marco TA1 Gas Bottle Replacement, Put the trumpet on the bottle: step 7, image 2 of 2
      • Put the trumpet on the bottle.
      • BE CAREFUL. Keep your fingers away from the trumpet and red circled moving parts: when the trumpet is on the gas bottle and you press it, it will honk!!
      Ask FixBot
    8. Marco TA1 Gas Bottle Replacement, Close the lock on the bottle: step 8, image 1 of 2 Marco TA1 Gas Bottle Replacement, Close the lock on the bottle: step 8, image 2 of 2
      • BE CAREFUL. The horn may honk if you press it too strong on the red marked part.
      Ask FixBot
    9. Marco TA1 Gas Bottle Replacement, Check that the lock it's completely sealed: step 9, image 1 of 2 Marco TA1 Gas Bottle Replacement, Check that the lock it's completely sealed: step 9, image 2 of 2
      • The red circled lock has to be like in the picture, out and up. If it's still inside, the trumpet may disconnect.
      • The blue circled part should be like in the picture, with no space between the components.
      Ask FixBot
    10. Marco TA1 Gas Bottle Replacement, You've finished!: step 10, image 1 of 1
      • Your gas horn it's now up and running, ready to be used again!
      Ask FixBot
There's no limit on the number of times you change the gas bottle.
Marco Spa
1,531 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 34
All Time: 665
