Up to 20% off select tools
MapKeyboard Tutorial
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
109
All Time:
1,764
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This video will show how to use the MapKeyboard software to map a broken key to another lesser used key. This will be useful if you have a keyboard with a broken key that cannot be replaced or repaired, but still want to continue to use that keyboard. This will not be a perfect fix, so for a more permanent solution, visit our How to Replace Keys on a Keyboard Guide.
      • 1. When one of your keyboard's keys is broken, you don't want to spend a lot of money to replace the entire keyboard because of one key
      • 2. You can use a software called "MapKeyboard"
      • 3. Start the software and select the key you will use to replace the broken key
      • 4. Select "ReMap selected key to" and select the broken key "G"
      • 5. Click on "Save layout" and the laptop will restart
      • 6. After restarting, you will find that the key you set can be typed with ā€œGā€ so that you can continue to use your keyboard without changing it
      • 7. If you want to restore the layout of the keyboard, you can start the software again, click on "Reset keyboard layout"
      • 8.After the restart, it will be restored
      Ask FixBot
Author
with
Laptop
1,029 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 109
All Time: 1,764
