Up to 20% off select tools
Manual recalibration
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
95
All Time:
957
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Guide on how to manually re-center the wheel. Helps when your physical wheel is not synced with in-game wheel and some other problems related to calibration.
    1. Manual recalibration, Manual recalibration: step 1, image 1 of 1
      • Open the Thrustmaster Control panel application and set the angle to 1080°
      • If you are using PlayStation, manually set rotation angle to 1080°
      Ask FixBot
      • Unplug and re-plug T-GT II to USB port.
      • Wait for auto-calibration to finish
      Ask FixBot
    2. Manual recalibration, Steer the wheel all the way to the left: step 3, image 1 of 1
      • Keep turning the wheel until you reach a physical stop
      Ask FixBot
    3. Manual recalibration, Steer the wheel all the way to the right: step 4, image 1 of 1
      Ask FixBot
    4. Manual recalibration, Center your wheel: step 5, image 1 of 1
      • Perfectly center your wheel.
      • Keep in mind that rotation is set to 1080°.
      Ask FixBot
    5. Manual recalibration, Press the indicated buttons: step 6, image 1 of 1
      • Press SHARE + OPTIONS + MODE buttons at the same time.
      • LED will flash if successful.
      • If you are using a different wheel, then a button combination will be different. You can find button combination list here.
      Ask FixBot
Finish Line
Author
with
Formica Fusca
2,626 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 95
All Time: 957
