Makita DT01 Trigger Switch Replacement
  1. Makita DT01 Trigger Switch Replacement, Battery: step 1, image 1 of 3 Makita DT01 Trigger Switch Replacement, Battery: step 1, image 2 of 3 Makita DT01 Trigger Switch Replacement, Battery: step 1, image 3 of 3
    • Lay the device down on its side.
    Ask FixBot
  2. Makita DT01 Trigger Switch Replacement: step 2, image 1 of 1
    • Pinch the indents on both sides of the battery.
    Ask FixBot
  3. Makita DT01 Trigger Switch Replacement: step 3, image 1 of 1
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
    Ask FixBot
  4. Makita DT01 Trigger Switch Replacement, Trigger Switch: step 4, image 1 of 1
    • Unscrew all six 15mm screws with a JIS1 screwdriver bit.
    Ask FixBot
  5. Makita DT01 Trigger Switch Replacement: step 5, image 1 of 1
    • Remove the top of the plastic drill case
    Ask FixBot
  6. Makita DT01 Trigger Switch Replacement: step 6, image 1 of 1
    • Remove the bottom of the plastic drill case
    Ask FixBot
  7. Makita DT01 Trigger Switch Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Use your tweezers to remove the black wire from the motor
    Ask FixBot
  8. Makita DT01 Trigger Switch Replacement: step 8, image 1 of 1
    • Use your tweezers to remove the red wire from the motor
    Ask FixBot
  9. Makita DT01 Trigger Switch Replacement: step 9, image 1 of 1
    • Your trigger switch should now be removed from your motor
    Ask FixBot
  10. Makita DT01 Trigger Switch Replacement: step 10, image 1 of 1
    • Use your tweezers to remove the red and black wires from the two-pronged plug
    Ask FixBot
  11. Makita DT01 Trigger Switch Replacement: step 11, image 1 of 1
    • Your trigger switch is now detached from the device
    Ask FixBot
Victoria Scira
250 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 1,065
