Up to 20% off select tools
Makita DT01 LED Light Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
75
All Time:
1,103
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
If your Makita DT01 drill has a light that flickers, or doesn't turn on entirely, here's a step-by-step guide on how to open your drill and replace the LED.
Before following this guide, inspect the light for any debris that could prevent it from functioning. Typically, debris buildup can be removed with a Clorox wipe and paper towel, or a soft, damp cloth with warm water. If the light still fails to function after it's cleansed, the issue is internal.
Step 3 requires you to reconnect the wires to the new LED. Make sure to use tweezers or similar tools to bend the wire into place once connected to the LED, otherwise, you could cause damage to the LED.
    1. Makita DT01 LED Light Replacement, LED Light: step 1, image 1 of 2 Makita DT01 LED Light Replacement, LED Light: step 1, image 2 of 2
      • Remove the battery pack from the bottom of the drill.
      • Using a screwdriver, remove the six screws on the side of the drill.
      • Remove the outer shell of the drill.
      Ask FixBot
    2. Makita DT01 LED Light Replacement: step 2, image 1 of 1
      • Locate the motor (left) and the trigger (right) and separate the chords connecting them.
      • Locate the LED cable (Circled) and disconnect the chord from the trigger.
      Ask FixBot
    3. Makita DT01 LED Light Replacement: step 3, image 1 of 1
      • Using your tweezers, remove the plastic tape wrapped around the LED light.
      • Remove white and black cables connected to the LED light.
      • Reconnect the two cables with the replacement LED light component.
      • Reconnect the light to the trigger and place all components back in the drill.
      • Reconnect the battery pack.
      Ask FixBot
Your drill light should now be working!
Author
with
Ya'Rub Al Manwari
201 Reputation
2 Guides authored
1 Guide Comment
Where can I buy the replacement led?
Ciaran Moss - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 75
All Time: 1,103
