Makita DT01 Battery Replacement
  1. Makita DT01 Battery Replacement, Battery: step 1, image 1 of 3 Makita DT01 Battery Replacement, Battery: step 1, image 2 of 3 Makita DT01 Battery Replacement, Battery: step 1, image 3 of 3
    • Lay the device down on its side.
    Ask FixBot
  2. Makita DT01 Battery Replacement: step 2, image 1 of 1
    • Pinch the indents on both sides of the battery.
    Ask FixBot
  3. Makita DT01 Battery Replacement: step 3, image 1 of 1
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
    Ask FixBot
Victoria Scira
250 Reputation
2 Guides authored
1 Guide Comment
Replacement for Makita DT01 Power Tool Battery
Type: Li-ion
Volt: 10.8V
Capacity: 3000mAh
Color: Black
Weight: 166g
Dimension: 50.75 x 50.20 x 77.80mm
You can contact this seller for a lower price if you want a quantity purchase of Makita DT01 replacement batteries on https://www.drill-battery.net.au/buybatt...
Drillbatterycomau - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 26
All Time: 882
