Making Visible the Users Library Directory in OS X Lion
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: step 1, image 1 of 2 Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: step 1, image 2 of 2
      • Many Macintosh users were excited when OS X 10.7 (Lion) was released, but after using it for a short time, many users realized that something was missing from lion.
      • The users Library directory is not where it it should be, infact, it is nowhere to be found. Fortunately, it is very simple to bring back the disappearing Library.
      Ask FixBot
    2. Making Visible the Users Library Directory in OS X Lion: step 2, image 1 of 1
      • To begin the process, you will need to go to your Applications folder, which can be found in your Finder side bar.
      • Once in the Applications folder, you will want to find the Utilities folder.
      Ask FixBot
    3. Making Visible the Users Library Directory in OS X Lion: step 3, image 1 of 1
      • After navigating to the Utilities folder you will need to scroll down to find the Terminal application.
      Ask FixBot
    4. Making Visible the Users Library Directory in OS X Lion: step 4, image 1 of 2 Making Visible the Users Library Directory in OS X Lion: step 4, image 2 of 2
      • Once you have opened Terminal, you will need to type chflags nohidden ~/Library/ and then press Enter.
      • This will immediately make your Library folder visible under your user.
      Ask FixBot
    5. Making Visible the Users Library Directory in OS X Lion: step 5, image 1 of 1
      • Once you have finished with Terminal, type exit to end your terminal processes. After you have typed this and hit enter you may quit out of Terminal.
      Ask FixBot
    6. Making Visible the Users Library Directory in OS X Lion: step 6, image 1 of 1
      • To hide the Library folder, simply type chflags hidden ~/Library and press Enter.
      • Remember to type exit and press Enter before quitting Terminal.
      Ask FixBot
Owen Cunneely
7,187 Reputation
1 Guide authored
Master Techs Member of Master Techs
Community
334 Members
8,156 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,769
