Up to 20% off select tools
Makerbot Digitizer stepper bracket Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
63
All Time:
366
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
If you've overheated your stepper, or want to help someone who has, then this is for you. This will show you how to disassemble your Digitizer with a minimum of effort.
    1. Makerbot Digitizer stepper bracket Replacement, Removing the turntable cap: step 1, image 1 of 2 Makerbot Digitizer stepper bracket Replacement, Removing the turntable cap: step 1, image 2 of 2
      • Use a flat spudger or screwdriver to remove the 1-1/2" cap from the turntable center.
      • There is a small indentation on the underside of one side of the cap.
      Ask FixBot
    2. Makerbot Digitizer stepper bracket Replacement, Loosen the turntable screw: step 2, image 1 of 1
      • Loosen the exposed T15 screw.
      • You do not need to remove it from the turntable, but it must be completely loosened.
      • It has a series of metal-rubber-metal washers, and if you leave the screw in the turntable, you don't need to mess with the washers.
      Ask FixBot
    3. Makerbot Digitizer stepper bracket Replacement, Remove turntable: step 3, image 1 of 3 Makerbot Digitizer stepper bracket Replacement, Remove turntable: step 3, image 2 of 3 Makerbot Digitizer stepper bracket Replacement, Remove turntable: step 3, image 3 of 3
      • Use two flat tools under both sides of the turntable to to pop it out.
      • The turntable slides down onto the bearing with some friction, but I've taken mine on and off 10 times and it still fits snugly.
      Ask FixBot
    4. Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: step 4, image 1 of 3 Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: step 4, image 2 of 3 Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: step 4, image 3 of 3
      • Remove two T15 screws that hold the stepper bracket in place.
      Ask FixBot
    5. Makerbot Digitizer stepper bracket Replacement, Snap some pictures: step 5, image 1 of 3 Makerbot Digitizer stepper bracket Replacement, Snap some pictures: step 5, image 2 of 3 Makerbot Digitizer stepper bracket Replacement, Snap some pictures: step 5, image 3 of 3
      • That's basically it. My stepper has enough slack to maneuver it around without further disassembly.
      Ask FixBot
    6. Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: step 6, image 1 of 3 Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: step 6, image 2 of 3 Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: step 6, image 3 of 3
      • To reinstall the turntable, the stepper side must go in first, in order for the turntable gears to align with the stepper gears.
      • Otherwise, the turntable will sit too high and not contact the stepper gear.
      Ask FixBot
To reassemble, just follow these instructions in reverse.
Author
with
Job McKee
241 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 63
All Time: 366
