Up to 20% off select tools
Maingear Vector Laptop Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
75
All Time:
1,401
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Community-Contributed Guide
Parts
Tools
      • pull off the black bezel around the deges
      • it is held on by double-sided tape. be careful not to break the bezel it is a somewhat thin plastic sheet.
      Ask FixBot
    1. Tool used on this step:
      Buy
      • carefully pry up the bottom of the screen. there is double-sided tape holding it to the back.
      • pry on one side at a time slowly and once you can fit a pair of tweezers befind the screen grab the tape. when yo pull the tape it will come off like 3m command hooks
      • be careful not to rip the tape
      • the tape is in two vertical strips about an inch from the edge
      Ask FixBot
      • the replacement screen is a lp156wfg(sp)(B2) on the maingear vector mg vctr001 1660ti from 2020
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. this is not a complete guide there is only enough info for you to know how to open it little steps are missing.
Author
with
djluke mon
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 75
All Time: 1,401
