Magna Outreach Rear tire Replacement
  1. Magna Outreach Rear tire Replacement, Rear Tire: step 1, image 1 of 1
    • Disconnect the rear brake cable
    Ask FixBot
  2. Magna Outreach Rear tire Replacement: step 2, image 1 of 1
    • Flip the bike over so that it is resting on the seat and handlebars.
    • Use an adjustable wrench to remove the nuts on both sides of the wheel that hold the wheel to the frame.
    • Lift the tire away from the frame and chain.
    Ask FixBot
  3. Magna Outreach Rear tire Replacement: step 3, image 1 of 1
    • Insert one tire lever under the tire and hook it onto a spoke. Insert the other tire lever next to the first and slide it along the rim to remove one side of the tire from the rim.
    Ask FixBot
  4. Magna Outreach Rear tire Replacement: step 4, image 1 of 1
    • Starting at the valve, pull the inner tube out of the gap between the rim and the tire.
    Ask FixBot
  5. Magna Outreach Rear tire Replacement: step 5, image 1 of 1
    • Pull the tire away from the rim.
    Ask FixBot
West Johnson
146 Reputation
1 Guide authored
USF Tampa, Team 1-14, Donnelly Fall 2014 Member of USF Tampa, Team 1-14, Donnelly Fall 2014
USFT-DONNELLY-F14S1G14
1 Member
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 23
All Time: 2,810
