Up to 20% off select tools
Magic Trackpad Battery Replacement
Views: 20K
View statistics:
Past 24 Hours:
10
Past 7 Days:
63
Past 30 Days:
350
All Time:
19,600
Comments: 4
4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
  • Coin
    $2.99
    4.7
    View
  • Spudger
    4.9
    1. Magic Trackpad Battery Replacement, Batteries: step 1, image 1 of 2 Magic Trackpad Battery Replacement, Batteries: step 1, image 2 of 2
      • Use a spudger or coin to twist out the battery door.
      Ask FixBot
    2. Magic Trackpad Battery Replacement: step 2, image 1 of 1
      • Slide out the two AA batteries.
      Ask FixBot
3 other people completed this guide.
Author
with
Ronnie
3,860 Reputation
5 Guides authored
4 Guide Comments
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - Reply Share
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - Reply Share
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz - Reply Share
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - Reply Share
Past 24 Hours: 10
Past 7 Days: 63
Past 30 Days: 350
All Time: 19,600
