Magic Bullet NutriBullet Rubber Gasket Replacement
  1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: step 1, image 1 of 1
    • Separate the blending blade lid from the cup.
    Ask FixBot
  2. Magic Bullet NutriBullet Rubber Gasket Replacement: step 2, image 1 of 2 Magic Bullet NutriBullet Rubber Gasket Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
    • Slowly pry the rubber gasket up.
    Ask FixBot
Geary Yu
1,277 Reputation
3 Guides authored
Cal Poly, Team 19-8, Maness Winter 2015 Member of Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Members
13 Guides authored
11 Guide Comments
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - Reply Share
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - Reply Share
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - Reply Share
Thanks a lot.
Kayla Martin - Reply Share
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - Reply Share
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 164
All Time: 38,281
