Magic Bullet NutriBullet Outside Casing Replacement
Views: 9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
132
All Time:
9,030
Comments: 7
3 comments on steps, 4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The exterior component of the NutriBullet’s powerbase consist of a silver, plastic shell casing. Use this guide to replace the cylindrical shell to ensure no leakage, exposure of wires or spinning components are showing through.
Tools
    1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: step 1, image 1 of 1
      • Unplug the device from the wall and turn the powerbase upside down.
      Ask FixBot
    2. Magic Bullet NutriBullet Outside Casing Replacement: step 2, image 1 of 2 Magic Bullet NutriBullet Outside Casing Replacement: step 2, image 2 of 2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      Ask FixBot
    3. Magic Bullet NutriBullet Outside Casing Replacement: step 3, image 1 of 1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      Ask FixBot
    4. Magic Bullet NutriBullet Outside Casing Replacement: step 4, image 1 of 1
      • Lift the power cord to remove it from the side slot on the curved base.
      Ask FixBot
    5. Magic Bullet NutriBullet Outside Casing Replacement: step 5, image 1 of 2 Magic Bullet NutriBullet Outside Casing Replacement: step 5, image 2 of 2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      Ask FixBot
    6. Magic Bullet NutriBullet Outside Casing Replacement: step 6, image 1 of 1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      Ask FixBot
    7. Magic Bullet NutriBullet Outside Casing Replacement: step 7, image 1 of 1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      Ask FixBot
    1. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: step 8, image 1 of 1
      • Wiggle the outside casing upward until it separates from the powerbase.
      • Hold the ring at the bottom of the powerbase to receive a better grip.
      Ask FixBot
5 other people completed this guide.
Angela Wong
1,177 Reputation
3 Guides authored
Cal Poly, Team 19-8, Maness Winter 2015 Member of Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Members
72 Guides authored
4 Guide Comments
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - Reply Share
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - Reply Share
So what happens next? What is one suppose to do? Stupid help, I would say
Mary Johnson - Reply Share
I tried step number 8 and the outside casing still won't slide off. What do I do now?
Euclid Taylor - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 132
All Time: 9,030
