Up to 20% off select tools
Magic Bullet NutriBullet Curve Base
Views: 5.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
149
All Time:
5,771
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Magic Bullet NutriBullet Curve Base, Curve Base: step 1, image 1 of 1
      • Unplug the device from the wall and turn the powerbase upside down.
      Ask FixBot
    2. Magic Bullet NutriBullet Curve Base: step 2, image 1 of 2 Magic Bullet NutriBullet Curve Base: step 2, image 2 of 2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      Ask FixBot
    3. Magic Bullet NutriBullet Curve Base: step 3, image 1 of 1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      Ask FixBot
    4. Magic Bullet NutriBullet Curve Base: step 4, image 1 of 1
      • Lift the power cord to remove it from the side slot on the curved base.
      Ask FixBot
    5. Magic Bullet NutriBullet Curve Base: step 5, image 1 of 2 Magic Bullet NutriBullet Curve Base: step 5, image 2 of 2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      Ask FixBot
    6. Magic Bullet NutriBullet Curve Base: step 6, image 1 of 1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      Ask FixBot
    7. Magic Bullet NutriBullet Curve Base: step 7, image 1 of 1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      Ask FixBot
Author
with
Geary Yu
1,295 Reputation
3 Guides authored
Cal Poly, Team 19-8, Maness Winter 2015 Member of Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 149
All Time: 5,771
