Up to 20% off select tools
Magic Bullet NutriBullet Activator Replacement
Views: 101K
View statistics:
Past 24 Hours:
15
Past 7 Days:
131
Past 30 Days:
596
All Time:
101,156
Comments: 70
23 comments on steps, 47 guide comments.
Go to guide comments
Completed: 64
64 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The top of the NutriBullet powerbase contains activator switches that are depressed when the blender jar is placed onto the base. When all of the switches are depressed the blender is activated. Depending on the specific model number there may be two (NB-101B) or three (NB-301) activator switches.
This replacement guide will provide instructions on how to replace these activators on a model with 3 switches, but the steps should be reasonably similar on different models.
    1. Magic Bullet NutriBullet Activator Replacement, Curve Base: step 1, image 1 of 1
      • Unplug the device from the wall and turn the powerbase upside down.
      Ask FixBot
    2. Magic Bullet NutriBullet Activator Replacement: step 2, image 1 of 2 Magic Bullet NutriBullet Activator Replacement: step 2, image 2 of 2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      Ask FixBot
    3. Magic Bullet NutriBullet Activator Replacement: step 3, image 1 of 1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      Ask FixBot
    4. Magic Bullet NutriBullet Activator Replacement: step 4, image 1 of 1
      • Lift the power cord to remove it from the side slot on the curved base.
      Ask FixBot
    5. Magic Bullet NutriBullet Activator Replacement: step 5, image 1 of 2 Magic Bullet NutriBullet Activator Replacement: step 5, image 2 of 2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      Ask FixBot
    6. Magic Bullet NutriBullet Activator Replacement: step 6, image 1 of 1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      Ask FixBot
    7. Magic Bullet NutriBullet Activator Replacement: step 7, image 1 of 1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      Ask FixBot
    1. Magic Bullet NutriBullet Activator Replacement, Outside Casing: step 8, image 1 of 1
      • Wiggle the outside casing upward until it separates from the powerbase.
      • Hold the ring at the bottom of the powerbase to receive a better grip.
      Ask FixBot
    1. Magic Bullet NutriBullet Activator Replacement, Rubber Covers: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Place the NutriBullet powerbase on the table so that the three rubber screw covers are visible along the bottom of the well. Remove the covers using either tweezers or your fingers.
      Ask FixBot
    2. Magic Bullet NutriBullet Activator Replacement, Top Screws: step 10, image 1 of 1
      • Remove the three 15mm screws with the Philips Head 2 Screwdriver.
      Ask FixBot
    3. Magic Bullet NutriBullet Activator Replacement: step 11, image 1 of 1
      • Turn the NutriBullet powerbase upside down and remove the plastic casing by lifting it up. You may have to wiggle the casing in order to break away any hardened material.
      Ask FixBot
    4. Magic Bullet NutriBullet Activator Replacement: step 12, image 1 of 1
      • Determine which activator(s) fail to work by applying pressure to them. Then, remove the two 15mm screws that hold the activators in place by using the Philips Head 2 screwdriver.
      • Only two of the three activator tabs have green micro switches that actually turn on the motor. Use a circuit tester on the power chord and press the two micro switches simultaneously to see if they complete the circuit. If not, one or both need to be replaced.
      Ask FixBot
    5. Magic Bullet NutriBullet Activator Replacement: step 13, image 1 of 3 Magic Bullet NutriBullet Activator Replacement: step 13, image 2 of 3 Magic Bullet NutriBullet Activator Replacement: step 13, image 3 of 3
      • Using slight tension, pull the loose activator from the slot.
      • The white plastic activator should fall out and they can now be replaced.
      Ask FixBot
    6. Magic Bullet NutriBullet Activator Replacement, Repairing internal switches: step 14, image 1 of 1
      • Open up the green switch. The metal tab and black button will fall out. Fiddle around with the metal switch on the inside to snap it back into place and then reassemble carefully. It should make a clicking noise.
      Ask FixBot
      • Before reassembling, you should clean up any material that has accumulated on the various parts. Be sure to keep water away from the motor, switches and other electrical components.
      Ask FixBot
64 other people completed this guide.
Author
with
Angela Wong
1,195 Reputation
3 Guides authored
Cal Poly, Team 19-8, Maness Winter 2015 Member of Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Members
72 Guides authored
47 Guide Comments
Seems to be almost complete info, however, where and how do I get the replacement parts?
Thank you!
Love&Peace!
Glow
Glow Wo - Reply Share
Could you please let me know where I might be able to obtain replacement activators? Mind broke when cleaning the machine.
Ron - Reply Share
Thank you. I would have went nuts looking for the screw under the rubber pieces. Would have probably destroyed the whole machine.
Joe Bailey - Reply Share
Thanks for the demonstration!
D S Jones - Reply Share
Perfect! Nice little machine that can still be serviced, unlike most of what is made today.
cward6681 - Reply Share
Past 24 Hours: 15
Past 7 Days: 131
Past 30 Days: 596
All Time: 101,156
