Up to 20% off select tools
Magic Bullet MB1001B Casing Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
107
All Time:
2,496
Comments: 5
5 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Are there cracks in your casing? This guide will help you replace the casing.
    1. Magic Bullet MB1001B Casing Replacement, Base Gear: step 1, image 1 of 3 Magic Bullet MB1001B Casing Replacement, Base Gear: step 1, image 2 of 3 Magic Bullet MB1001B Casing Replacement, Base Gear: step 1, image 3 of 3
      • Use pliers to grip the gear inside of the top of the device.
      • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
      • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
      • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
      Ask FixBot
    1. Magic Bullet MB1001B Casing Replacement, Casing: step 2, image 1 of 1
      • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
      Ask FixBot
    2. Magic Bullet MB1001B Casing Replacement: step 3, image 1 of 1
      • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
      Ask FixBot
    3. Magic Bullet MB1001B Casing Replacement: step 4, image 1 of 1
      • Remove the black base plate.
      Ask FixBot
    4. Magic Bullet MB1001B Casing Replacement: step 5, image 1 of 1
      • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
      Ask FixBot
    5. Magic Bullet MB1001B Casing Replacement: step 6, image 1 of 1
      • Remove the white plastic cable guide.
      Ask FixBot
    6. Magic Bullet MB1001B Casing Replacement: step 7, image 1 of 1
      • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
      Ask FixBot
    7. Magic Bullet MB1001B Casing Replacement: step 8, image 1 of 1
      • Remove the black base.
      Ask FixBot
    8. Magic Bullet MB1001B Casing Replacement: step 9, image 1 of 1
      • Remove the three white rubber spacers with the spudger.
      Ask FixBot
    9. Magic Bullet MB1001B Casing Replacement: step 10, image 1 of 1
      • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
      Ask FixBot
    10. Magic Bullet MB1001B Casing Replacement: step 11, image 1 of 1
      • Remove the motor.
      Ask FixBot
2 other people completed this guide.
Author
with
Kelly McGartland
567 Reputation
2 Guides authored
Cal Poly, Team 12-13, Maness Fall 2015 Member of Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 107
All Time: 2,496
