Magellan Roadmate 9055-LM Back Panel Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
73
All Time:
577
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Removing the back panel is the required step to replace anything for the gps
Tools
    1. Magellan Roadmate 9055-LM Back Panel Disassembly, Magellan Roadmate 9055-LM Back Panel Disassembly: step 1, image 1 of 1
      • Flip your device with back panel facing up.
      Ask FixBot
    2. Magellan Roadmate 9055-LM Back Panel Disassembly: step 2, image 1 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 2, image 2 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 2, image 3 of 3
      • Unscrew four Phillips #0 screws from the back panel.
      Ask FixBot
    3. Magellan Roadmate 9055-LM Back Panel Disassembly: step 3, image 1 of 2 Magellan Roadmate 9055-LM Back Panel Disassembly: step 3, image 2 of 2
      • Unscrew two Phillips #0 screws from the back panel.
      Ask FixBot
    4. Magellan Roadmate 9055-LM Back Panel Disassembly: step 4, image 1 of 2 Magellan Roadmate 9055-LM Back Panel Disassembly: step 4, image 2 of 2
      • Use a plastic opening tool to pop the right side of the panel.
      Ask FixBot
    5. Magellan Roadmate 9055-LM Back Panel Disassembly: step 5, image 1 of 1
      • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
      • Gently lift up the back panel.
      Ask FixBot
    6. Magellan Roadmate 9055-LM Back Panel Disassembly: step 6, image 1 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 6, image 2 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 6, image 3 of 3
      • Remove the tape.
      • Unplug the cable for the speaker.
      Ask FixBot
    7. Magellan Roadmate 9055-LM Back Panel Disassembly: step 7, image 1 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 7, image 2 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 7, image 3 of 3
      • Remove the cable of the battery.
      • Tape removal is not necessary.
      Ask FixBot
    8. Magellan Roadmate 9055-LM Back Panel Disassembly: step 8, image 1 of 1
      • Place the back panel gently on the table.
      Ask FixBot
YuChe Chang
202 Reputation
2 Guides authored
UMass Dartmouth, Team 1-5, Catania Fall 2016 Member of UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 73
All Time: 577
