Magellan RoadMate 1440 Screen Replacement
  1. Magellan RoadMate 1440 Screen Replacement, Magellan RoadMate 1440 Back Cover Disassembly: step 1, image 1 of 1
    • Place the GPS with the screen facing down.
    Ask FixBot
  2. Magellan RoadMate 1440 Screen Replacement: step 2, image 1 of 2 Magellan RoadMate 1440 Screen Replacement: step 2, image 2 of 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
    Ask FixBot
  3. Magellan RoadMate 1440 Screen Replacement: step 3, image 1 of 2 Magellan RoadMate 1440 Screen Replacement: step 3, image 2 of 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
    Ask FixBot
  4. Magellan RoadMate 1440 Screen Replacement: step 4, image 1 of 3 Magellan RoadMate 1440 Screen Replacement: step 4, image 2 of 3 Magellan RoadMate 1440 Screen Replacement: step 4, image 3 of 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
    Ask FixBot
  5. Magellan RoadMate 1440 Screen Replacement: step 5, image 1 of 3 Magellan RoadMate 1440 Screen Replacement: step 5, image 2 of 3 Magellan RoadMate 1440 Screen Replacement: step 5, image 3 of 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
    Ask FixBot
  6. Magellan RoadMate 1440 Screen Replacement, Battery: step 6, image 1 of 2 Magellan RoadMate 1440 Screen Replacement, Battery: step 6, image 2 of 2
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
    Ask FixBot
  7. Magellan RoadMate 1440 Screen Replacement: step 7, image 1 of 2 Magellan RoadMate 1440 Screen Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
    Ask FixBot
  8. Magellan RoadMate 1440 Screen Replacement: step 8, image 1 of 2 Magellan RoadMate 1440 Screen Replacement: step 8, image 2 of 2
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
    Ask FixBot
  9. Magellan RoadMate 1440 Screen Replacement, Screen: step 9, image 1 of 1
    • Replace the device's screen.
    Ask FixBot
  10. Magellan RoadMate 1440 Screen Replacement: step 10, image 1 of 3 Magellan RoadMate 1440 Screen Replacement: step 10, image 2 of 3 Magellan RoadMate 1440 Screen Replacement: step 10, image 3 of 3
    • It may be necessary to get help from a friend to hold the device stable while removing the screen.
    • Using two hands, pull back the tabs holding the screen in place.
    • Use a spudger to help use leverage to remove the screen, if necessary
    Ask FixBot
  11. Magellan RoadMate 1440 Screen Replacement: step 11, image 1 of 2 Magellan RoadMate 1440 Screen Replacement: step 11, image 2 of 2
    • Raise the switch locking the ribbon cable in place.
    • Using twesers, pull the ribbon cable from the socket.
    Ask FixBot
  12. Magellan RoadMate 1440 Screen Replacement: step 12, image 1 of 2 Magellan RoadMate 1440 Screen Replacement: step 12, image 2 of 2
    • With the ribbon cable removed, the screen is completely disconnected from the device.
    • To replace the ribbon cable, press the two tabs to push the head into the socket.
    Ask FixBot
Miller Hall
352 Reputation
2 Guides authored
Clemson, Team 7-3, Benson Spring 2016 Member of Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
4 Members
7 Guides authored
1 Guide Comment
This is an amazingly clear and precise set of steps that I was able to use to remove the broken screen on my Magellan Roadmate 1475T.
I followed the directions exactly up to step 9(“removing the screen”) which I skipped over and went directly to step 11(“removing the ribbon cable from the socket”).
By detaching the ribbon cable from the mother board at this point, it eliminated the fumbling and possible damage to the connections on the mother board, and gave me direct access to the front frame which was holding the screen. When the front frame was separated from the rest of the device it was very easy then to just pop out the broken screen from the frame without needing any tools or extra hands.
Thank you for this extremely helpful tutorial!
Morgan - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 28
All Time: 719
