Up to 20% off select tools
MageGee Key Caps Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
164
All Time:
6,549
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
If the keys are sticking on your MageGee mechanical keyboard, follow this guide to replace them. If you purchase the keyboard from Amazon, you already have practically every tool you need.
    1. MageGee Key Caps Replacement, Key Caps: step 1, image 1 of 1
      • Test out which keys are the ones that are sticking and giving you trouble.
      • If you have a lot of keys that stick you might want to take note of which ones they or, or alternatively replace your entire keyboard's key caps.
      Ask FixBot
    2. MageGee Key Caps Replacement: step 2, image 1 of 2 MageGee Key Caps Replacement: step 2, image 2 of 2
      • Remove the damaged keys with a key cap remover by gently pressing onto the desired key cap. Pull gently and the key cap will come off.
      • Make a note of where the keys are located so you know where to replace them.
      Ask FixBot
    3. MageGee Key Caps Replacement: step 3, image 1 of 1
      • When removing the keys, remember where each one goes. You can place it in the order it was taken out to help you keep track.
      Ask FixBot
    4. MageGee Key Caps Replacement: step 4, image 1 of 2 MageGee Key Caps Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Check the keyboard for any blockages or obstructions and remove them with tweezers.
      • Alternatively: use your fingers or any other grabbing tools like a pair of small tongs.
      Ask FixBot
    5. MageGee Key Caps Replacement: step 5, image 1 of 1
      • Clean the area with a cloth or antibacterial wipe to remove any debris you might have missed.
      • Remember, water damages electronics so be very careful with this step.
      Ask FixBot
    6. MageGee Key Caps Replacement: step 6, image 1 of 1
      • Check your removed key caps to see if they are still functional, if not, you may want to get additional key caps to replace the old ones.
      Ask FixBot
    7. MageGee Key Caps Replacement: step 7, image 1 of 1
      • If your key caps were damaged, take out corresponding new key caps to replace the old damaged ones.
      Ask FixBot
    8. MageGee Key Caps Replacement: step 8, image 1 of 3 MageGee Key Caps Replacement: step 8, image 2 of 3 MageGee Key Caps Replacement: step 8, image 3 of 3
      • Insert the new key caps in by lining it up with the other keys and pressing it gently into the correct place.
      Ask FixBot
    9. MageGee Key Caps Replacement: step 9, image 1 of 1
      • Test out your new key caps and double check its functionality.
      Ask FixBot
    10. MageGee Key Caps Replacement: step 10, image 1 of 2 MageGee Key Caps Replacement: step 10, image 2 of 2
      • Plug in your keyboard and there you have it, a functional mechanical keyboard.
      • If your keyboard is not fixed, it may be a circuit issue which will result in needing your whole keyboard needing to be replaced.
      Ask FixBot
Now your keys on your mechanical keyboard should be working as good as new.
Author
with
Lisa Nguyen
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 164
All Time: 6,549
