Up to 20% off select tools
MagLite 4D O-Ring Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
140
All Time:
2,174
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
A properly maintained Maglite flashlight can work for a long time. It can easily work for over twenty years! However, sometimes old parts breakdown and your beloved Maglite may no longer turn on. If you see moisture in the head of your Maglite, this guide is for you.
The model we will look at today is the 4D, from the late 1990s to early 2000s. This guide should also work for other D-cell battery Maglites made after the 4D model.
If you see moisture in the flashlight head, you might have a damaged O-ring. This guide will show you how to look at and replace the O-ring.
    1. MagLite 4D O-Ring Replacement, O-ring: step 1, image 1 of 1
      • Unscrew the Maglite head.
      • Remember, to unscrew a flashlight head, turn it counterclockwise.
      Ask FixBot
    2. MagLite 4D O-Ring Replacement: step 2, image 1 of 1
      • Remove the lens.
      Ask FixBot
    3. MagLite 4D O-Ring Replacement: step 3, image 1 of 1
      • Remove the reflector cone.
      Ask FixBot
    4. MagLite 4D O-Ring Replacement: step 4, image 1 of 1
      • Examine the O-ring for damage.
      • The O-ring is the black rubber band around the flashlight head.
      Ask FixBot
    5. MagLite 4D O-Ring Replacement: step 5, image 1 of 1
      • Remove the damaged O-ring.
      • The O-ring is flexible, so it should be easy to pull off. Or, it may fall off if it is broken.
      Ask FixBot
    6. MagLite 4D O-Ring Replacement: step 6, image 1 of 1
      • Place the new O-ring in the same place as the original.
      • The O-ring is flexible, so simply pull it on gently.
      Ask FixBot
    7. MagLite 4D O-Ring Replacement: step 7, image 1 of 1
      • Wipe the moisture from the reflector cone with a paper towel or soft cloth.
      Ask FixBot
    8. MagLite 4D O-Ring Replacement: step 8, image 1 of 1
      • Wipe the moisture from the lens with a paper towel or soft cloth.
      Ask FixBot
    9. MagLite 4D O-Ring Replacement: step 9, image 1 of 1
      • Replace the reflector cone.
      • Replace the lens.
      Ask FixBot
    10. MagLite 4D O-Ring Replacement: step 10, image 1 of 1
      • Screw on the Maglite head.
      • Remember, to screw on a flashlight head, turn it clockwise.
      Ask FixBot
    11. MagLite 4D O-Ring Replacement: step 11, image 1 of 1
      • Test the Maglite by turning it on.
      • If your Maglite turns on, your work is complete!
      Ask FixBot
If your Maglite turns on, it should be ready to go! If your Maglite does not turn on, the next step is to look at the battery compartment. Please see another guide for this step.
Author
with
Laura Allen
223 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 140
All Time: 2,174
