Macintosh Powerbook 5300cs Hard Drive Replacement
  1. Macintosh Powerbook 5300cs Hard Drive Replacement, Battery: step 1, image 1 of 1
    • The battery compartment is located in the front-right side of the laptop.
    Ask FixBot
  2. Macintosh Powerbook 5300cs Hard Drive Replacement: step 2, image 1 of 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
    Ask FixBot
  3. Macintosh Powerbook 5300cs Hard Drive Replacement, Keyboard: step 3, image 1 of 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
    Ask FixBot
  4. Macintosh Powerbook 5300cs Hard Drive Replacement: step 4, image 1 of 2 Macintosh Powerbook 5300cs Hard Drive Replacement: step 4, image 2 of 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
    Ask FixBot
  5. Macintosh Powerbook 5300cs Hard Drive Replacement: step 5, image 1 of 3 Macintosh Powerbook 5300cs Hard Drive Replacement: step 5, image 2 of 3 Macintosh Powerbook 5300cs Hard Drive Replacement: step 5, image 3 of 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
    Ask FixBot
  6. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: step 6, image 1 of 3 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: step 6, image 2 of 3 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: step 6, image 3 of 3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
    Ask FixBot
  7. Macintosh Powerbook 5300cs Hard Drive Replacement: step 7, image 1 of 1
    • With a Torx #9 screwdriver, remove the three .30 in. screws that hold the metal frame in place.
    Ask FixBot
  8. Macintosh Powerbook 5300cs Hard Drive Replacement: step 8, image 1 of 3 Macintosh Powerbook 5300cs Hard Drive Replacement: step 8, image 2 of 3 Macintosh Powerbook 5300cs Hard Drive Replacement: step 8, image 3 of 3
    • Remove the metal chasis that holds the hard drive.
    Ask FixBot
  9. Macintosh Powerbook 5300cs Hard Drive Replacement: step 9, image 1 of 1
    • In order to remove the hard drive, remove the four .22 in. screws circled in red found on both sides of the metal chassis with a Torx #9 screwdriver.
    Ask FixBot
  10. Macintosh Powerbook 5300cs Hard Drive Replacement: step 10, image 1 of 2 Macintosh Powerbook 5300cs Hard Drive Replacement: step 10, image 2 of 2
    • Pull the hard drive out.
    Ask FixBot
2 other people completed this guide.
Ronan
72 Reputation
4 Guides authored
Cal Poly, Team 6-1, Regan Fall 2011 Member of Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 45
All Time: 2,369
