Up to 20% off select tools
Macintosh PowerBook 165c Display Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
93
All Time:
3,364
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the display.
    1. Macintosh PowerBook 165c Display Replacement, Display: step 1, image 1 of 1
      • Orientate the computer right side up and open the display case to reveal the display.
      • Use a plastic opening tool to remove the two small plastic plugs located on the display case just below the display.
      Ask FixBot
    2. Macintosh PowerBook 165c Display Replacement: step 2, image 1 of 1
      • Use a T8 torx screwdriver to remove the two, 7.7mm long screws that were revealed by removing the plastic plugs.
      • Twist counterclockwise to remove the screw.
      • Caution: Once the screws are removed, the display is only held by two screws. Handle delicately.
      Ask FixBot
    3. Macintosh PowerBook 165c Display Replacement: step 3, image 1 of 1
      • Grip the two bottom corners of the plastic display cover and gently pull towards yourself so that the display cover rotates about the top of the display case.
      • The display cover should release from top.
      • Remove the display case.
      Ask FixBot
    4. Macintosh PowerBook 165c Display Replacement: step 4, image 1 of 1
      • Locate the black connector on the right of the display. The connector can be identified by the pink, light blue, and white wires protruding from its side.
      • Remove the black connector from the circuit board by pulling it away from its adapter.
      Ask FixBot
    5. Macintosh PowerBook 165c Display Replacement: step 5, image 1 of 1
      • Using a T8 torx screwdriver, remove the four, 10.8mm long screws from the corners of the display.
      • Caution: The display is no longer supported and must be handled with care.
      Ask FixBot
    6. Macintosh PowerBook 165c Display Replacement: step 6, image 1 of 1
      • Carefully tilt the display downwards and rest it on the keyboard.
      Ask FixBot
    7. Macintosh PowerBook 165c Display Replacement: step 7, image 1 of 3 Macintosh PowerBook 165c Display Replacement: step 7, image 2 of 3 Macintosh PowerBook 165c Display Replacement: step 7, image 3 of 3
      • Locate the orange ribbon cable on the back of the display.
      • Open the white tab fastener by pulling it outward.
      • Remove the orange ribbon cable by gently pulling it away from the opened tab fastener.
      • The display is now free.
      Ask FixBot
Author
with
Jason
110 Reputation
4 Guides authored
Cal Poly, Team 6-3, Regan Fall 2011 Member of Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 93
All Time: 3,364
