Macintosh PowerBook 1400 Series RAM Replacement
    1. Macintosh PowerBook 1400 Series RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the device upside down and then locate the battery latch near the front of the device.
      Ask FixBot
    2. Macintosh PowerBook 1400 Series RAM Replacement: step 2, image 1 of 1
      • Slide the latch to the left to release the battery.
      Ask FixBot
    3. Macintosh PowerBook 1400 Series RAM Replacement: step 3, image 1 of 1
      • Continue holding the latch then gently pull the battery out of the device.
      • Place the battery in a safe location.
      Ask FixBot
    1. Macintosh PowerBook 1400 Series RAM Replacement, CD-ROM Drive: step 4, image 1 of 1
      • Locate the CD-ROM Drive latch.
      Ask FixBot
    2. Macintosh PowerBook 1400 Series RAM Replacement: step 5, image 1 of 1
      • Slide the latch to the right to release the CD ROM drive.
      Ask FixBot
    3. Macintosh PowerBook 1400 Series RAM Replacement: step 6, image 1 of 1
      • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
      • Place the CD ROM drive in a safe location.
      Ask FixBot
    1. Macintosh PowerBook 1400 Series RAM Replacement, Keyboard: step 7, image 1 of 1
      • Locate the speaker cover.
      Ask FixBot
    2. Macintosh PowerBook 1400 Series RAM Replacement: step 8, image 1 of 1
      • Press firmly on each end of the speaker cover and slide it to the left.
      Ask FixBot
    3. Macintosh PowerBook 1400 Series RAM Replacement: step 9, image 1 of 1
      • Gently lift the speaker cover to remove it.
      Ask FixBot
    4. Macintosh PowerBook 1400 Series RAM Replacement: step 10, image 1 of 1
      • Lift the keyboard up from the back using a spudger(wedge side).
      Ask FixBot
    5. Macintosh PowerBook 1400 Series RAM Replacement: step 11, image 1 of 1
      • Gently lift the keyboard until only the ribbon cable remains attached.
      Ask FixBot
    6. Macintosh PowerBook 1400 Series RAM Replacement: step 12, image 1 of 1
      • Tilt the keyboard away from the screen.
      Ask FixBot
    7. Macintosh PowerBook 1400 Series RAM Replacement: step 13, image 1 of 1
      • Locate the six screws that secure the heatsink.
      Ask FixBot
    8. Macintosh PowerBook 1400 Series RAM Replacement: step 14, image 1 of 1
      • Remove the six screws from the heatsink using the Philips #1 screwdriver.
      Ask FixBot
    9. Macintosh PowerBook 1400 Series RAM Replacement: step 15, image 1 of 1
      • Lift the heatsink from the side closest to the laptop screen.
      Ask FixBot
    10. Macintosh PowerBook 1400 Series RAM Replacement: step 16, image 1 of 1
      • Remove the heatsink.
      Ask FixBot
    11. Macintosh PowerBook 1400 Series RAM Replacement: step 17, image 1 of 1
      • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
      Ask FixBot
    12. Macintosh PowerBook 1400 Series RAM Replacement: step 18, image 1 of 1
      • Detach the ribbon cable.
      Ask FixBot
    13. Macintosh PowerBook 1400 Series RAM Replacement: step 19, image 1 of 1
      • Remove the keyboard.
      Ask FixBot
    1. Macintosh PowerBook 1400 Series RAM Replacement, Memory (RAM): step 20, image 1 of 1
      • Identify RAM Memory stick
      • These are the upgradeable RAM Memory sticks, they must be removed first
      Ask FixBot
    2. Macintosh PowerBook 1400 Series RAM Replacement: step 21, image 1 of 1
      • Gently grasp the ram on the far end as shown in the picture and then pull up and away from the right side of the computer
      Ask FixBot
    3. Macintosh PowerBook 1400 Series RAM Replacement: step 22, image 1 of 1
      • Remove the upgradeable RAM stick
      • If the upgradeable RAM stick is all you are repairing you can end the guide here, however to remove the factory installed RAM please continue
      Ask FixBot
    4. Macintosh PowerBook 1400 Series RAM Replacement: step 23, image 1 of 1
      • Gently grasp the factory installed RAM by grabbing each end as shown in the picture and pull the stick directly up
      Ask FixBot
    5. Macintosh PowerBook 1400 Series RAM Replacement: step 24, image 1 of 1
      • Remove the factory installed RAM memory module
      Ask FixBot
5 other people completed this guide.
Kian Dinyari
146 Reputation
1 Guide authored
Cal Poly, Team 10-39, Forte Spring 2011 Member of Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 43
All Time: 5,106
