Macintosh PowerBook 1400 Series Hard Drive Replacement
  1. Macintosh PowerBook 1400 Series Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
    Ask FixBot
  2. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 2, image 1 of 1
    • Slide the latch to the left to release the battery.
    Ask FixBot
  3. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 3, image 1 of 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
    Ask FixBot
  4. Macintosh PowerBook 1400 Series Hard Drive Replacement, CD-ROM Drive: step 4, image 1 of 1
    • Locate the CD-ROM Drive latch.
    Ask FixBot
  5. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 5, image 1 of 1
    • Slide the latch to the right to release the CD ROM drive.
    Ask FixBot
  6. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 6, image 1 of 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
    Ask FixBot
  7. Macintosh PowerBook 1400 Series Hard Drive Replacement, Keyboard: step 7, image 1 of 1
    • Locate the speaker cover.
    Ask FixBot
  8. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 8, image 1 of 1
    • Press firmly on each end of the speaker cover and slide it to the left.
    Ask FixBot
  9. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 9, image 1 of 1
    • Gently lift the speaker cover to remove it.
    Ask FixBot
  10. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 10, image 1 of 1
    • Lift the keyboard up from the back using a spudger(wedge side).
    Ask FixBot
  11. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 11, image 1 of 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
    Ask FixBot
  12. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 12, image 1 of 1
    • Tilt the keyboard away from the screen.
    Ask FixBot
  13. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 13, image 1 of 1
    • Locate the six screws that secure the heatsink.
    Ask FixBot
  14. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 14, image 1 of 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
    Ask FixBot
  15. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 15, image 1 of 1
    • Lift the heatsink from the side closest to the laptop screen.
    Ask FixBot
  16. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 16, image 1 of 1
    • Remove the heatsink.
    Ask FixBot
  17. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 17, image 1 of 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
    Ask FixBot
  18. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 18, image 1 of 1
    • Detach the ribbon cable.
    Ask FixBot
  19. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 19, image 1 of 1
    • Remove the keyboard.
    Ask FixBot
  20. Macintosh PowerBook 1400 Series Hard Drive Replacement, Hard Drive: step 20, image 1 of 1
    • Locate and identify the two screws that attach the hard drive to the computer.
    Ask FixBot
  21. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 21, image 1 of 1
    • Remove the screws with a Phillips #0 screwdriver.
    Ask FixBot
  22. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 22, image 1 of 1
    • Once the screws are removed, lift up the end of the hard drive using your finger tips.
    Ask FixBot
  23. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 23, image 1 of 1
    • Fully lift the hard drive vertically against the side of the computer.
    Ask FixBot
  24. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 24, image 1 of 1
    • Push a finger down onto the plastic strap.
    Ask FixBot
  25. Macintosh PowerBook 1400 Series Hard Drive Replacement: step 25, image 1 of 1
    • Remove the hard drive from the computer by pushing down on the plastic strap and pulling up on the hard drive.
    Ask FixBot
11 other people completed this guide.
Jeffrey Huntley
248 Reputation
1 Guide authored
Cal Poly, Team 10-39, Forte Spring 2011 Member of Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Members
6 Guides authored
1 Guide Comment
Hi iFixIt thanks for all the details BUT the keyboard can indeed stay in
when changing the hard drive. Just slide it a bit to the right after step
11, the ribbon cble does not take any damage. SO: from step 12 jump
straight to step 20. The heat sink can stay untouched, which i find not
unimportant to mention. Regards, TB75
TB75 - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 90
All Time: 9,973
