Up to 20% off select tools
MacBook Unibody Model A1278 RAM Replacement
Views: 195K
View statistics:
Past 24 Hours:
6
Past 7 Days:
44
Past 30 Days:
232
All Time:
194,871
Comments: 34
13 comments on steps, 21 guide comments.
Go to guide comments
Completed: 296
296 people have marked this guide "completed." Will you be next?
Favorites: 85
85 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Accessing the RAM in this computer is straightforward and requires minimal disassembly.
    1. MacBook Unibody Model A1278 RAM Replacement, Access Door: step 1, image 1 of 1
      • With the case closed, place the Unibody top-side down on a flat surface.
      • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
      Ask FixBot
    2. MacBook Unibody Model A1278 RAM Replacement: step 2, image 1 of 1
      • The access door should now be raised enough to lift it up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 RAM Replacement, Battery: step 3, image 1 of 1
      • Be sure the access door release latch is vertical before proceeding.
      • Grab the white plastic tab and pull the battery up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 RAM Replacement, Lower Case: step 4, image 1 of 1
      • Remove the following eight screws securing the lower case to the chassis:
      • One 3 mm Phillips screw.
      • Four 3.5 mm Phillips screws.
      Ask FixBot
    2. MacBook Unibody Model A1278 RAM Replacement: step 5, image 1 of 1
      • Using both hands, lift and remove the lower case off the upper case.
      Ask FixBot
    1. MacBook Unibody Model A1278 RAM Replacement, RAM: step 6, image 1 of 1
      • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
      • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      Ask FixBot
    2. MacBook Unibody Model A1278 RAM Replacement: step 7, image 1 of 1
      • After the RAM chip has popped up, pull it straight out of its socket.
      • Repeat this process if a second RAM chip is installed.
      Ask FixBot
296 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
21 Guide Comments
Open back of unit, press two grey sides surrounding the chip, pull out the top (leave the bottom 2gb in) put in the new (4gb) chip; now there are 6gb of ram.
mrstiffanyjudson - Reply Share
I just upgraded to 2 4GB chips. Works fine sofar!
Sten Folkerman - Reply Share
That's awesome! I thought that I could only upgrade the RAM to 4GB (which is what I have now). Can you give me the type of RAM that you installed? I have this exact model MacBook.
Jonathan - Reply Share
Uh oh. I replaced my 2 1GB ram with 2 2GB. I turned it on and it beeps at me about every second, the front status light blinks in time, but nothing else....what next?
dunkelcreature - Reply Share
Sounds like bad RAM. I would contact who you purchased it from. If it was us, email support [at] ifixit [dot] com
Scott Dingle - Reply Share
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 232
All Time: 194,871
