MacBook Unibody Model A1278 Optical Drive Replacement
    1. MacBook Unibody Model A1278 Optical Drive Replacement, Access Door: step 1, image 1 of 1
      • With the case closed, place the Unibody top-side down on a flat surface.
      • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
      Ask FixBot
    2. MacBook Unibody Model A1278 Optical Drive Replacement: step 2, image 1 of 1
      • The access door should now be raised enough to lift it up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 Optical Drive Replacement, Battery: step 3, image 1 of 1
      • Be sure the access door release latch is vertical before proceeding.
      • Grab the white plastic tab and pull the battery up and out of the Unibody.
      Ask FixBot
    1. MacBook Unibody Model A1278 Optical Drive Replacement, Lower Case: step 4, image 1 of 1
      • Remove the following eight screws securing the lower case to the chassis:
      • One 3 mm Phillips screw.
      • Four 3.5 mm Phillips screws.
      Ask FixBot
    2. MacBook Unibody Model A1278 Optical Drive Replacement: step 5, image 1 of 1
      • Using both hands, lift and remove the lower case off the upper case.
      Ask FixBot
    1. MacBook Unibody Model A1278 Optical Drive Replacement, Optical Drive: step 6, image 1 of 1
      • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
      • On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
      • If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
      Ask FixBot
    2. MacBook Unibody Model A1278 Optical Drive Replacement: step 7, image 1 of 1
      • Disconnect the camera cable by pulling the male end straight away from its socket.
      Ask FixBot
    3. MacBook Unibody Model A1278 Optical Drive Replacement: step 8, image 1 of 1
      • Use a spudger to pry the optical drive connector straight up off the logic board.
      Ask FixBot
    4. MacBook Unibody Model A1278 Optical Drive Replacement: step 9, image 1 of 1
      • Remove the two Phillips screws securing the subwoofer to the upper case.
      • The longer of the two screws is on the right.
      Ask FixBot
    5. MacBook Unibody Model A1278 Optical Drive Replacement: step 10, image 1 of 1
      • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
      • Lift the subwoofer off the optical drive, and set it above the computer.
      Ask FixBot
    6. MacBook Unibody Model A1278 Optical Drive Replacement: step 11, image 1 of 1
      • Remove the two Phillips screws securing the camera cable bracket to the upper case.
      • The leftmost screw may remain captive in the camera cable.
      Ask FixBot
    7. MacBook Unibody Model A1278 Optical Drive Replacement: step 12, image 1 of 1
      • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
      Ask FixBot
    8. MacBook Unibody Model A1278 Optical Drive Replacement: step 13, image 1 of 1
      • Lift the optical drive from its right edge and pull it out of the computer.
      • The hard drive cable may become disconnected from the logic board when removing the optical drive. Ensure it is connected during reassembly.
      Ask FixBot
    1. MacBook Unibody Model A1278 Optical Drive Replacement, Optical Drive: step 14, image 1 of 1
      • Remove the optical drive cable by pulling it straight away from the optical drive.
      • This connector is particularly deep, so be sure to pull away from the drive at the center of the connector.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      Ask FixBot
    2. MacBook Unibody Model A1278 Optical Drive Replacement: step 15, image 1 of 1
      • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
      Ask FixBot
108 other people completed this guide.
8 Guide Comments
I ruined my laptop because of this guide.
The step 6 says it's a connector that comes of (sub-woofer), mine was welded, I broke it, I cannot fix it.
i am frustrated, and I know I should only blame myself for following blindly that guide.
But at least I thought I should let people know : be careful when removing that sub-woofer connector!!!
Thomas C - Reply Share
I also broke the sub-woofer connector away from the board, the connection to the board is very fragile, however I managed to solder the connector back on with a very fine soldering iron, (tricky). but it worked. I don't think it is really necessary to disconnect the sub-woofer cable to remove the optical drive, I'll find out when I get a new one to replace the old broken one. To remove the subwoofer cable it would be necessary to hold the connector in place while the plug is very carefully prized up from the lead side without moving the connector socket.
John Chinnery - Reply Share
Completed this one successfully. Now running OCZ 256 GB SSD in main bay and WD Black 320GB in optical bay.
Daniel Reyes - Reply Share
PLEASE change Step 6 to not blindly pop the subwoofer cable off of the logic board. I also have broken this connection by following the instructions. The comments do not print out/are not shown on the pdf! Some people (like me) may never see these comments until too late.
Jonny - Reply Share
My computer had a different optical drive than shown. Instead of the screws going through the body of the drive, it was secured by two screws at the corners opposite the screw by the connectors (i.e, along the wall where the CD slot is). In addition, in order to repair the drive, black tape sealing the unit had to be peeled back in order to open it (and the screws underneath the tape were placed slightly differently).
italtrav - Reply Share
Past 24 Hours: 12
Past 7 Days: 41
Past 30 Days: 117
All Time: 109,148
